Enables or disables authentication username configuration to use the Principal Name in the certificate as the username.
x509v3 | Specifies x509v3 public-key authentication. |
username | Specifies X509v3 authentication username configuration. |
overwrite | Specifies that when radius-password-auth is turned on, to use the Principal Name in the certificate as the username. |
on | Specifies to enable X509v3 authentication username configuration. |
off | Specifies to disable X509v3 authentication username configuration. (Default). |
Off.
The following example enable using the Principal Name in the certificate as the username.
# configure ssh2 x509v3 username overwrite on Note: This command is applicable only if X509v3 'radius-password-auth' command is turned on.
This command was first available in ExtremeXOS 32.2.
